Written by Marc Levac
Friday, 29 December 2006 08:02 |
MGB Setup Library
The ModelGasBoats.com boat setup library is a reader and manufacturer submitted listing of different boat setups.
Do you have that new super-duper hull and you want to set it up so it can go 60 mph? Not sure of the proper center of gravity setting? What motor and running gear are others using on hulls similar to yours? This will be the place to check out!
The ModelGasBoats.com boat setup library will provide the basic information to help you set your boat up like the pros! (or at least similar to what other boaters are doing).
Do you have the hot ticket on your boat? Download the Boat Setup Form, fill it out and send it back to ModelGasBoats.com. We encourage you to share your setup information so that others may learn how to have a properly running and handling boat. As more information is distributed, we'll have fewer frustrated boaters, and the more we can attract and retain new modelers to the exciting world ofboating! We'd love to have multiple setups for each boat as well as have as many different boats represented.
