Tuning
marc created the topic: Tuning
#17956
noworknguy replied the topic: Tuning
How does one change the timeing?
#17957
INEEDSPOTS replied the topic: Re: Tuning
what timing? ignition timing? intake timing? exhaust timing?
to change (you can usually only RAISE, not LOWER) intake timing, you can either A. trim the amount needed off the skirt of the piston or B. grind the bottom of the intake port the amount needed to bring the timing to where you want. To change the exhaust timing, you grind on the roof (top) of the exhaust port the amount needed to bring the timing to where you want.
#17958
The following user(s) said Thank You: noworknguy
Thank you .Don
#17965
