Shaft Oiler
marc created the topic: Shaft Oiler
Product Review Article...
A good way to keep you flex shaft lubricated without having to remove it everytime...
Read more...
#19398
kennydao replied the topic: Shaft Oiler
hi
where do i can buy thic item
thanks
#19399
smokeater2005 replied the topic: Re: Shaft Oiler
Try google, www.mhz-powerboats.com, arrowshark products... The shaft oiler you end up using will depend on your; wallet size, flex-shaft Diameter, setup- stuffing tube with oiler vs. surface prop flex shaft holder with oiler, space you have to work with inside of your hull and so on. For me it was a matter of flex shaft diameter and hull space. im going with the mhz one cause it doesnt have the cross bar which lets me place it right up next to the radio box and run a small line from an "oil bag" to the shaft holder/oiling unit/ shaft saver collet.
Price is a matter of figuring how long you have to wait to afford an item and weighting that against your will to wait that long...
#19412
