Simple Oiler or Greaser
  • Canadian Hot Rod RC Boats
  • Topic Author
  • Offline
More
15 years 6 months ago - 15 years 6 months ago #15409 by Canadian Hot Rod RC Boats
Simple Oiler or Greaser was created by Canadian Hot Rod RC Boats
I see a few guys looking for 'greaser's' and oilers - here's a few simple ways I make mine - I use a small hand pump greaser or oilers - I don't think they (the adapter on tubing) need to be huge mine are pretty compact
Here's a few :) 3 diff types I use
I make mine from 1/2 bar stock - I drill a 5/16 hole in center then 2 x M4 ... 90 degrees apart
I use a short M4 fitting and cap it when not using it
found a few 90 degree too
simple for a tank if u want a oiler
Last edit: 15 years 6 months ago by Canadian Hot Rod RC Boats.
  • Topic Author
  • Offline
More
15 years 6 months ago - 15 years 6 months ago #15410 by Canadian Hot Rod RC Boats
Replied by Canadian Hot Rod RC Boats on topic Re: Simple Oiler or Greaser
To make it even easier .... I noticed this in my tool box (old Arrow Shark shaft saver - alum )
cgi.ebay.ca/Arrow-Shark-Shaft-...=item518f747055
Already has one 1/4" center hole and a M4 side bolt/screw - mine's a used 1
opened it up (slowly ...) 1/4" to 5/16" [img] u could open up with files or hand grinder too ...... http://www.modelgasboats.com/media/kunena/attachments/legacy/images/DSC04151.JPG[/img]
to keep this simple I retaped (cleaned threads) hole to M4 and used a short M4 fitting - I taped 5/16" tubing with M4 too so fitting screws thru (need to deburr inside tube
no allen set screw on this one
I polished it and left one side Red so u could see the Arrow Shark one
simple and clean (I think........... :laugh:
later :laugh:
Oh and I use Red loctite on the fittings and set screw ( a touch of heat to take them off ..) and they seem to stay well
Now I just need some of Scott's cool ball valves and small tank ... ... ;)
I use this type Pro Boat greaser with diff grease
  • INEEDSPOTS
  • Offline
  • GO SLOW... TURN LEFT
More
15 years 6 months ago #15411 by INEEDSPOTS
Replied by INEEDSPOTS on topic Re: Simple Oiler or Greaser
ive done the same...but using a split collar. No set screw to dent the stuffing tube. I dont use it anymore though...got tired of the mess the oil constantly made.
More
15 years 6 months ago - 15 years 6 months ago #15412 by
Replied by on topic Re: Simple Oiler or Greaser
Hi Canadian.
What a beautiful oiler setup on your pics!
Actually I have invented almost precisely the same for my own unfinished mono.
I have 3 of the same oiler(s) as you. One for the gearbox and two for the twin tubes to the twin drives.
Only thing is that I won't be able to get such a fine CNC design on the bar as you are presenting, and I consider threading the nippels in order to make a connection with a small piece of inside threaded metal tube from oiler to driveshaft.
My intention is NOT to put "shutting valves" to the oilers. When the boat is at rest, I'll simply attach a little piece of tape on the hole on top of the oiler. That should prevent oil from dripping out through the driveshafts. Well that's the theory.
Anyway: Good job. Its very inspiring!
Last edit: 15 years 6 months ago by .
  • Topic Author
  • Offline
More
15 years 6 months ago - 15 years 6 months ago #15413 by Canadian Hot Rod RC Boats
I stop the oil or grease mess from inside by using a 1/4" nylon washer up against stuffing tube and usually put small pc hose or ziptie against washer to hold washer against tube
hose works better - but the nylon washer stops alot of the mess
I also only use .029 wall tubing so the M4 set screw on side of fitting barely makes a mark on tube - def does not 'dent' it
I use small containers so not a issue to drain it out
to grease just hold nylon washer against stuffing tube and with a needle tip (on grease gun I use) just pump it in ... then a antenna cap makes a good cover for nipple
  • Scott
  • Offline
  • Devoted Enthusiast ... MGB Technical advisor
More
15 years 6 months ago #15414 by Scott
Replied by Scott on topic Re: Simple Oiler or Greaser
Good lookin stuff guys ...
Time to create page: 0.151 seconds
