My inline rigger gets run ... O'yea we have ignition !
  • Scott
  • Topic Author
  • Offline
  • Devoted Enthusiast ... MGB Technical advisor
More
15 years 3 months ago - 15 years 3 months ago #16393 by Scott
Couple strut tweaks and a prop swap gave us 78mph running as if on rails.
I'm stoked this beast is a rush to drive.
Same day unknown at the time one cylinder was hurt from a previous blown water line overheating engine :blink: reason it was sagging off every so often.
Last edit: 15 years 3 months ago by Scott.
More
15 years 2 months ago #16397 by Ozpulse
That big beast is really screaming along, well done Scott! B)
More
15 years 2 months ago #16398 by mitchesx
Scott - you look like a kid in a Candy store!!!! Awesome job!!! :woohoo:
More
15 years 2 months ago #16401 by Mercury94
Awesome Scott!! Are going to race it at the NAMBA nationals?
More
15 years 2 months ago #16405 by isuzudude
Fantastic Job Scott!!!!!!!!!!! Looks Super!!!!!!!!!!!!
More
15 years 2 months ago #16417 by marc
Awesome Scott! Very impressive! Great job!
  • Scott
  • Topic Author
  • Offline
More
15 years 2 months ago #16419 by Scott
Thanks guys, quite rewarding when all the hours thinking while producing nothing going on and on before wood gets cut finally comes together and actually works as you had hoped.
I'm pretty stoked hull runs as well as it does with what is quite conservative a prop on during the video shoots.
Hope to find mid 80's after getting the teething pains out of the way ... motors got the balls without a doubt, just need to prop the beast so cable/drive components are not getting beat too death :blink:
  • Scott
  • Topic Author
  • Offline
More
15 years 1 month ago - 15 years 1 month ago #17085 by Scott
Major updates on entire drive train and more ... :laugh:
* Carbon fiber strut taking 8mm prop shaft and MUCH beefier overall.
* MTC 8mm prop shaft stepped to 1/4"
* H.D. golden strand Suhner square end drive cable.
* Custom Hot pipes & manifolds
* Reworked HMH rpm pipes with hot pipe flanges attached allowing pipe swaps on same manifolds.
Last edit: 15 years 1 month ago by Scott.
More
15 years 1 month ago #17087 by marc
Man that boat is bad ass!!!
Scott, is the back of your carb cover closed? Are the carbs pulling air from the tub?
  • Scott
  • Topic Author
  • Offline
More
15 years 1 month ago - 15 years 1 month ago #17092 by Scott
;) Thank you Marc ...
Yes the boxed in area is covered all sides except that area facing tubs interior.
Airflow feeding carbs comes in along exhaust side and from behind ( For Now )
* Am waiting on a few NACA ducts and will be placing one within the forward tank access cover so I get "Pass threw" air which hopefully may find me even more power / consistency.
Time to create page: 0.190 seconds
