Rebuilt Aeromarine Avenger pro
david36pt created the topic: Rebuilt Aeromarine Avenger pro
Chapter 1
Hi Guys
I buy this model from UK , used in bad shape until the autobailers and Drive where secure with silicone!!!!
Getting the work started by plugging all the holes in the wood, including the side opening for the carb side Zenoah (Now is an RZ254 RCMK).
Cover all holes made previously, including new for autobailers .
Openings on the front panel of wood, for floats.
In this model the air intake is short and requires far back the engine because the spark plug and let the correct center of gravity, the fiber was increased approximately 1.5cms in height and in length 3Cms.
Placement of a Nasca front vents in order to cool the engine.
Regards
#18543
bh_trade replied the topic: Re: Rebuilt Aeromarine Avenger pro
Looks like a lot of work. Curious to see further pics as you progress.
#18555
The following user(s) said Thank You: david36pt
marc replied the topic: Rebuilt Aeromarine Avenger pro
Ah the joys a fiberglass work! :) looks like your have it under control though, nice work.
www.modelgasboats.com
#18564
david36pt replied the topic: Re: Rebuilt Aeromarine Avenger pro
Hi Marc Many thanks
It s not easy to keep calm......RSSS
Just on question Marc
The fuel deposit goes to the front in the midle .
outboard strut OR Inside?
Whats the major diference in this hull using the one or another?
Many thanks
#18567
Preparing another episode...
#18597
finish of the new cover of the pipe , putty and tomorow the first base and , color toprepare paint job.
I don t have the set up of this boat but in the opening of the hull to pass the tube of the driveline i found not in the center of the hull but few mms to the rigth side (hull up side down).
Can someone help me ???(Marc??)
Many thanks
#18677
#18679
More Days....More hours working...Putty , base , putty...
#18691
More hours ...more painting ..just need the finish
#18710
Rysquedases replied the topic: Re: Rebuilt Aeromarine Avenger pro
Is that paint made out of the finest wood because it would make venere jealous. Alot of talent with that air brush, wow.
VERY NICE
#18756
Time to create page: 0.453 seconds
