Tech Article...by Scott Schneider
A step-by-step tutorial on how to modify an RCMK S/SX 254 Engine ... *All R254 Cylinders
To begin, I wish to make it clear that many of the designs and fundamentals being shared herein have been learned from published sources of information as well as from self-taught tricks. The working blend of modifications presented are from many years of trial and error testing while working with small displacement 2-stroke engines.
The use and application of this knowledge being applied to the RCMK engine is what we hope to share here.
Information as presented, will be worded simple and to the point. If you don't agree with or understand what's been said, please feel free to share your insight or questions with the community within the MGB forums. A link is provided at the bottom of the article.
Note: Many of the modifications being done look very close to what was being done within the Zenoah G-260 “Engine Porting” article, but they differ in enough ways that you need to take notice of the explanations contained at each step.
Let’s get started. Disassemble your RCMK engine and follow along. This should help you "do-it-yourself" engine modifiers build a very powerful RCMK marine racing engine.
Crank Case and Crank Shaft ...
*This step is optional, "Turbo Crank and Cases mod". (Used ONLY with side exhaust designs)
| Here is what the Modified Turbo cut of the crankshaft's leading edge counter weights looks like. |
As the crank spins, the displacement of air/fuel is directed outwards towards the crankshaft main bearings aiding in their lubrication. As the leading edge of the modified counter weights clears the inner case entering the transfer passage cut away, the displacement of the air/fuel is directed into the flow that is headed up the transfer passages. Another benefit is that by controlling the air/fuel within case area, the engine has less crankcase fuel pooling and tends to load up less and run cleaner when coming up from lower RPM. (Only the leading edges of crankshaft’s counter weights need to be modified.)
* Each case half gets a further enhanced trough cut into the case at the leeward edge of the rotation side.
* The crankshaft’s leading edge counter weights get ground into a slight bevel/sloping wedge profile. (Nothing any more radical than shown is necessary.)
Piston ...
* This next step is for those wishing to explore the upper RPM range power gains of GREATER intake duration.
This modification is done by altering the intake side skirt of the piston and NOT cutting on the cylinder!
| Close up of the eyebrow cuts and 1st vertical cuts made on INTAKE SIDE transfer passage. | Here is the wedge of material cast into the roof of the divider, DO NOT disturb or hit if possible. |
| Here is the amount of material removed in the undercut. You DO NOT contact the bore edge but stay in behind it. Take the undercut all the way to the port's roof. ** Be VERY precise in having the profile of the undercut the same on both sides. The intent here is that the outflow of air/fuel now is tilted slightly more rearward away from the exhaust port than stock. * Note the edge that the dental pick is on. If followed out into the bore it would be just behind the spark plug hole. Make sure this angle is the SAME on both sides! |
Here you now can see the increases in cross sectional area within the transfer passages. We HAVE NOT cut along the outside edges of the passages, only at both ends. Note: The angle on the edge of Intake side transfer passage (Top of photo), it should match the crankcases along the scribe lines of the turbo ramping blend in shown earier. |
The reason for this is so that the air/fuel traveling withing the transfer passages has to increase its speed at the point of exiting. This gives the ports' roof and general port shape greater control over the out-flowing mixture. This directional control is a MAJOR component in the shaping of the engine's power band.
Next ...
Using the 1/4" ball end cylinder cutter, cut the ROOF of the exhaust port into a gentle arched profile as shown. Very little if any material needs to be removed on the outer most corners. Most will be within the center area. You do NOT want to widen the exhaust port any further!
The best exhaust timing specification in my honest opinion on the RCMK engines is approximately 180 degrees.
* Due to RCMK changing specs on the parts in an ongoing basis for greater reliability, the EX 180* timing specs are best set using a degree wheel instead of a fixed dimentional number *
Next ...
NEXT ...
Attach your intake manifold to cylinder. Note where the cylinder's intake passage and the shape of the manifold differ and match them accordingly. Trim the gasket to fit as well.
FINALLY...
| Here the final trick ... Using a THICK flexible CA glue, you put a bead around the seal's outside diameter at the outer bearing race. This will help prevent a seal blowout while running at high RPM/ power levels. ** Clean with a STRONG degreaser such as MEK using an ear swab prior to glueing in the seal. |
Supplement
The steps below are 100% optional and are ONLY set up tricks preferred on my own modified RCMK engines.
* The reason for these modifications is to further stablize and more accuratly hold the connecting rod in the center of the crank shaft big end bearing.
In checking RCMK's machining tollerances, I have found that the engine is VERY square and true with the center line of the bore and the axis is perfect with the crankcase and cylinder's bolt pattern. Tightening up of the piston's "Small End" thrust washers can therefore successfully be done.
Final notes:
Unlike the Zenoah "Engine Porting", on the RCMK the divider bridge between the transfer passages is NOT touched, though you can sharpen the edge if you wish.
The modifications shown above are nothing exotic, in doing approximately eight of the S-254 engines so far, the ones done as shown above run the best! These engines seem to do best with more conservative exhaust timing and modest increases in transfer area. You DO NOT need to do wild radical mods to get these engine to run Very Strong!
I do highly recommend doing the basic modifications as shown FIRST, omitting the piston skirt mod... Run it! Then go back in and cut the intake side skirt as shown ... compare the performance.
If you choose to get crazy doing wilder port alteration you will want to have a known baseline, so go after these modifications in steps that will show you what you are gaining or losing along the way.
Regards,
Scott Schneider
MGB Technical Advisor
